keithwong
May 03, 2016Aspirant
How to backup and restore configuration for 4 switches (stacked)
Dear All,
I would like to figure out how to fullly backup configuration from 4 switches that they have formed stack currently ( 1 GUI manage 4 switches)
Does there any procedure i can follow ?
I am afraid that if i just backup the running config by "Show run", once i made a mistake in the configuration, i don't know how to restore the configuration.
Do i need to re-form the stack before restore the configuration ? or the backuped configuration has included the stack config ? if so, which switch i should choose to restore the config ?
Thank You
- JohnRoNETGEAR Employee Retired
Hello keithwong,
Welcome to the community!
You will have to issue a save config command to save the configuration settings of the stack. Please click here to learn more regarding switch stack configuration files.
I hope this helps. Let us know if you have more questions.
Thanks,
- keithwongAspirant
Hi John,
Thanks for your reply.
I have read the link you provided and it is useful.
Question: how could i restore the configuration to these staked switches ?
Do i need to re-form the stack first ? or I can restore it via the GUI "Download" ?
Thank You
Hello keithwong,
Yes, you will have to re-form the stack. Please also take note that the configuration file can only be downloaded to the Master Stacking Unit.
Thanks,
