parkck's avatar
parkck
How to make network failover or redundancy?
HI
                    -------- Line 1 -----------
Rounter  ----|                                  | ---- Network swich ----- PC
                    -------- Line 2 -----------
I need to make
Line 1 and Line 2 connect to network switch
When Line 1 disconnect then Line 2 take over.
I knew when line 1 and 2 connect to same switch then network loop.
Any better IDEA?
  • Hi parkck ,
    Welcome to community,
    There is two plans for you.
    Plan A : Lyaer 3 plans: (Need you switch to support routing feature)
    You can configure static or dynamic routing to achieve network redundancy and load sharing through routing priority configuration and routing strategy on both links
    Plan B: Lyaer 2: (Need you Router to have LAN port and support STP feature)
    Connect the two lines directly to the router's LAN port,Through the STP protocol, loop detection can be carried out and one link can be interrupted during operation to realize redundancy of two links
    If you can provide netgear switch model and router model, I can offer more Suggestions
    Thank you
    • parkck's avatar
      parkck
      Thank you for reply this.
      This is Local network (Class C) 2 strusture communications each others not such as 2 internet connections.
      How about loop network/protocol? Do i need CISCO?
      Thanks.
      • kevin_hong's avatar
        kevin_hong
        Apprentice
        Hi parkck ,
        Plan C:
        If there was only one Internet WAN port in your Router, i think you do not need two links from switch to router.
        For example(Simple network):
        Internet --------- Wan port-------Router-----192.168.1.0-----Swtich=========192.168.1.0 / 192.168.2.0
        Key point:
        Can you provide the detailed model of the router?   It affect what scheme should be used if you really need to connect two links.
        BTW:
        For Layer 3 plan you can choose netgear switch that support routing,  such as Smart switch(F4 GS728TPP) or Manage Switch M4300...etc
        For Layer 2 pan you can choose netgear switch that support STP, such as Smart switch F4 or S350...etc
ProSupport for Business
