htagawa
Nov 14, 2022Guide
I cannot access over https on OSver 12.0.17.9
I recently updated my M4300 from version 12.0.15.4 to version 12.0.17.9. When I did so, I confirmed that I could no longer connect via HTTPS. Before the work was done, http was disabled and https wa...
htagawa
Nov 15, 2022Guide
Thank for you reply.
>Have read and followed the advise using http on port 49151 ?
Yes, I followed the advise, but I cannot access to switch using http on port 49151. I think this is affected by "no ip http server" in configuration.
the configuration enable ssh and https, and disable http and telnet. but I can access SSH and AV UI via http but Main UI on http and https.
when I access to http://"hostname"/, then I redirect to http://"hostname"/#/login and a screen appears where I can select between AV UI and MainUI.
when I choose AV UI, I can access AV UI.
when I choose MainUI, I redirect to http://"hostname":49151/v1/base/cheetah_login.html, and my browser is giving me the error ERR_NETWORK_CHANGED and won't let me access the site.
when I access to https://"hostname"/, my browser is giving me the error ERR_SOCKET_NOT_CONNECTED and won't let me access the site.
I wrote down a part of "show run all"
no ip http server
ip http port 49151
ip http secure-server
ip ssh server enable
no ip telnet server enable
I would like to reconfigure https via SSH, how do I do this via SSH.
I tried regenerate certificate via SSH, then the switch said "Please disable HTTPS before changing the certificate."
if i should submit some information to olve this problem. please teach me.
htagawa
Nov 15, 2022Guide
Additional Information, reconfigure HTTP secure-server did not help..
but Main UI via port 49151 was accessble when I enabled "ip http sever"
###comman##
ip http server
no ip http secure-server
config
crypto certificate generate
exit
- schumakuNov 16, 2022Guru - Experienced User
Yes, this reflects what I've suspected and spotted during a short test. Appears https support is gone (at least for the moment), and the informations from the RB look incomplete for a real world production switch. LaurentMa - several things are wrong svo.
- htagawaNov 16, 2022Guide
Thank you schumaku for reply.
If NetGear has some recommended action or workaround to encrypt communication, I will follow and try that.it is not desiable sitation to login and settig with non-encrypted communication.
- InformaticaCOGJan 17, 2023Aspirant
We also have the same problem and can't find the way to access the Web GUI via https even with firmware upgrade 12.0.17.10 (we have updated it from version 12.0.15.7).
Is this a recognized bug by Netgear? Are they working in solving it? Is there any workaround?
Thanks in advance.
