smiya
May 20, 2019Aspirant
I want to disable STP on specific ports only
I want to disable STP on specific ports only. (I do not want to disable the entire STP)
In [Switchng]-[Ports]-[PortConfigration] Check the port you want to disable.
Select STPmode to Disable an...
smiya
May 22, 2019Aspirant
I'm thinking about setting with a trunk port, but I want to think with an access port as much as possible.
msi
May 23, 2019Luminary
In your case and since you explained your topology later as in the initial post one 1 of the 2 links will be blocked by both STP and RSTP.
Technicaly you could consider MSTP - ignoring the originally vendor-specific PVST and RPVST/PVST+ modes - but then again, schumaku 's suggestion of creating an LAG on both ends and tag all VLANs on the LAG interface is proven to work (for me) and provides proper redundancy where both links can be used by all VLANs.
However the Dell switch needs to support link aggregation with LACP. You might also have to fiddle out what mode (dynamic or static LAG) works with both vendors.
Keep your STP configuration simple and it will work reliably when loops occur. Don't try to outsmart it ;-)
- smiyaMay 23, 2019Aspirant
Thank you.
This Netgear does not have MSTP configured.
The Netgear is mobile and VLAN 1 is also used for important communication.
If you set MSTP, does it affect all ports using VLAN 1 or VLAN2 or VLANx?
