simonleungxyz
Apr 10, 2024Aspirant
How to disable TCP Port 4444
Greetings!
I was told by the network security guy saying that my M4250 switch has a vulnerability on TCP Port 4444, I found out it is using on the web based terminal window on the admin gui. I have already disable all telnet, ssh services, but the network security team doesn't happy on that.
Is there any way to stop the port 4444?
Thanks for any input. (The screen capture of the scan result is attached for your reference)
Simon
Generally valid answer is to put up some ACL to the switch config.
- simonleungxyzAspirant
Hi schumaku , thanks for getting back. Yup, I have just put in a few lines on the IP ACL to block the questioning port. Have a good day!
Simon
- ErwinLNETGEAR Moderator
Hello simonleungxyz
Was your question answered? In this case could you give us feedback on the situation and accept the posts here as a solution to make it more visible to other users?
Thanks in advance!
Have lovely day,
Erwin
Netgear Team
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
