tjgoodma
Mar 08, 2016Aspirant
IEEE 802.3x Pause Frames - Receiving, but not Transmitting
I have enabled IEEE 802.3x Symmetric Flow Control on Ports 21 and 22 of a M7100-24X switch. When running "show interfaces status" from the CLI, Ports 0/21 and 0/22 indicate Flow Control Status "Active" and Flow Control:Enabled. As expected.
I then set up a source node on Port 21 to transmit Unicast traffic to a destination node on Port 22. The Port 21 device has intentionally been configured to transmit at twice the throughput that the Port 22 device's receiver is capable of processing. I would like to see Port 21's transmitter "slow down" the rate of its messages to match the Port 22 device's capabilities, with no packets dropped, using IEEE 802.3x Pause Frames on both links as the slow-down mechanism.
The Port 22 device is sending Pause frames to the switch, as expected. The switch appears to be obeying the Pause frames and slowing down the transmission rate to Port 22.
However, the switch is not sending any Pause frames back to the Port 21 device (as reported in switch TX Statistics and in MAC RX Statistics within the Port 21 device). The result is that the Port 21 device continues blasting traffic at its maximum rate, and many of those frames get dropped, presumably within the switch.
How do I enable Pause Frame transmission back to Port 21? My understanding of the documentation is that "Symmetric" Flow Control will enable both transmission & reception of Pause Frames, but it's unclear what triggers Pause Frame transmission.
- JohnRoNETGEAR Employee Retired
Hello tjgoodma,
Welcome to the community!
Yes, you are correct "Symmetric Flow Control" allows the switch to both respond to and generate MAC control PAUSE frames. May I please know what firmware is your M7100-24X is running?
Looking forward to your response.
Thanks,
- tjgoodmaAspirant
Hi JohnRo,
Thanks for the reply.
My firmware was out-of-date, but I just upgraded it to 11.0.0.18. I confirmed that the update was successful. The Web GUI looks slightly different and I was able to re-apply my Flow Control configurations on ports 21 & 22.
I'm still not seeing any Pause frames being transmitted. Here are some traces from the CLI after running for a while:
(M7100-24X) (Config)#show flowcontrol
Flow Control Flow Control RxPause TxPause
Intf Oper Mode
[deleted ports 0/1 thru 0/20]
0/21 Active Symmetric 0 0
0/22 Active Symmetric 128010 0
0/23 Active Symmetric 0 0
0/24 Active Symmetric 0 0(M7100-24X) (Config)#show interface counters
Port InOctets InUcastPkts InMcastPkts InBcastPkts InDropPkts
0/21 54534328704 3049 0 0 0
0/22 6057600 0 0 0 0[0/21 InOctets is very large, InUcastPkts is very small...but InDropPkts=0?]
Port OutOctets OutUcastPkts OutMcastPkts OutBcastPkts OutDropPkts
0/21 23056 0 164 135 0
0/22 72132066895 33303830 237 205 0[lots of traffic obviously making it out to 0/22, coming from 0/21]
As a follow-on question, is the Port 21 device required to use Auto-Negotiation to tell the switch that it's capable of symmetric flow control (receiving Pause Frames), or should the Flow Control setting in the Netgear switch be enough to turn on Pause Frame transmission to 0/21? I'm NOT using Auto-Negotiation in either the Port 21 or Port 22 devices.
Thanks,
tjgoodma
Hi tjgoodma,
Sorry for not getting back to you right away. Can you try reversing the source and destination and then try the test again. See if we'll get an rx pause on the new interface.
Thanks,
