rassel_rabbi's avatar
rassel_rabbi
Follower
Nov 04, 2025
Inquiry: 24×1 Gbps Copper + 2x10G Copper & 4×10 G SFP+ Uplink - Layer‑3 Switch (non‑PoE)
Hello,
I am looking for a Layer‑3 switch from NETGEAR with the following specifications:
24 ports of 1 Gbps copper RJ‑45 (non‑PoE)
2 ports of 10 Gbps copper & 4 ports of 10 Gbps SFP+ uplinks
Full Layer‑3 routing features (static routing, inter‑VLAN routing, etc.)
I previously used the GSM4328S, but I understand that it has been declared End‑of‑Life (EoL). Could you please advise if NETGEAR currently offers a model that matches or closely matches the above requirements? If there is none, I’d appreciate suggestions for the closest alternative.
  • schumaku's avatar
    schumaku
    Could Netgear confirm the GSM4328S is not EoL and continues to be available?
    On a side note, this list does not reflect the effective GSM4328S specs. It has only four (4) 10 Gb capable ports, two 10 Gbps copper for RJ45, and two 10 Gbps SFP+ ports; these ports usage is not limited to uplink only.
  • The exact specification you’re looking for isn’t available in the current NETGEAR lineup, since no recent model offers 24×1G plus 2×10G copper and 4×10G SFP+ with full Layer-3 features. The GSM4328S is still the closest match, though it only provides four 10 Gbps ports total and its availability depends on the region. The most realistic alternative is moving to an M4300 model and adjusting the copper/SFP+ mix based on what NETGEAR still ships.
ProSupport for Business
