Propers
Aug 25, 2018Tutor
Install new fan from the start on JGS516PE
I had some bad experience in the past with using 3rd party fans with switches and firewalls, mainly that every company wires fan headers in their own way and the new expensive fan just burns out as the moment you connect it and power the router on. Then you discover that it pins n the fan are in wrong order....
I ordered "JGS516PE" switch AND "Noctua NF-A4x20 5V" fan, is there information on how headers on this switch are wired? I am unable to find any schematics for the board.
If you know a place where I can find more info on this, please share. Thank you
Why change the fan on a factory new switch, immediately breaking the ProSafe Lifetime Warranty?
- PropersTutor
This topic is not about warranty, it is about changing factory installed fan to comparable 3rd party fan.
There is nothing inspiring about the fact that replacing an easily serviceable part with one that matches or exceeds specifications of the original - according to your statement voids warranty. This does not excuse the company from making schematics and pin layout information available as consumers have the right to repair and modify their products.
Just so you know, blanket claims like - if you touch anything we void your warranty, can be brought in to question in small claims court or in arbitration, if change or modification made was reasonable and done in compliance with standards that manufacturer puts forth. The manufacturer has specifications for what performance fan should produce and it was replaced with one that met or exceeded those specifications and done so in compliance with standards they put forth, the claim can not be made that it would have performed any different from the original part.
I will gladly challenge them if they tried to pull this one out. However, I think like the majority of companies Netgear cares about their customers and will honor their warranty unless major negligence on the part of the customer is found. And negligence should void warranty without a dobt.
Which is why I am here looking for accurate information on how fan pins are laid out.
For Netgear a fan (or for the sake of it also a switch internal power supply) is not an easy serviceable part, thus the pinout and fan specs are unlikely to become available. It might be easy for us two souls here to do it - however another fan has a different characteristic in RPM vs. airflow, so the intended cooling is not in place, leading to other unexpected problems. That's why we will never get what you are looking for here.
