robfantini's avatar
robfantini
IP address is incorrect in logs.
we have a M4100-50G-POE+    lagged to a GSM7352Sv2.
logs for the M4100 on screen and at rsyslog server show the address for the GSM7352Sv2.
Note there is also a GSM7224V2 lagged to the GSM7352Sv2 .  Its logs show correct address.
suggestions to fix?  or is it a bug?
more info:
for the m4100:
logging console 7
logging host "10.1.3.46" ipv4 514 debug
logging syslog
logging cli-command
for gsm7352:
logging host "10.1.3.46" ipv4 514 info
logging syslog
logging cli-command
  • Retired_Member's avatar
    Retired_Member
    Jul 18, 2017
    robfantini
    re: "1. Upload config-file from Switch"    so just save a 'Text Configuration' .   Correct?
    no, you need to copy configuration file to laptop.
    An example for CLI command:
    First, setup one TFTP server on laptop(example IP is 1.1.1.1)
    Second, execute command as 'save'
    Third, execute command as 'copy nvram:startup-config tftp://1.1.1.1/m4100-config'
    re: "Then erase the configure in the switch"   .     from cli what is the command for that?
    execute command as 'clear config'
    Then download the configuraiton file via CLI command as below:
    copy tftp://1.1.1.1/m4100-config nvram:startup-config
      Retired_Member
      Hi robfantini
      Welcome to the community!
      Please check the Management Interface configuration, is it same as your management VLAN IP?
      Web GUI go to 'System-->Management-->System Information', check the 'Management Interface' config.
      Hope it helps!
      EricZ
      NETGEAR employee
      • robfantini's avatar
        robfantini
        yes it looks to me to be the same. attached are screen shots
ProSupport for Business
