epmryan
May 19, 2016Follower
IP Subnet-Based VLANs and ARPs
I am trying to wrap my head around a concept involving subnet based VLANs and how ARPs for those IP subnets are classified into the correct VLAN. So for example let's say I have untagged traffic ingr...
Evans-o
Oct 11, 2016NETGEAR Expert
Hi epmryan,
Thanks for joining our online community.
I just wanted to reccommend that you look at the following excerpt starting from page 37 of the Software Administration Manual (for M5300-28G-POE+ (GSM7228PSv1h2) proSAFE 24+4 L2+ Gigabit Stackable Managed Switch) if it might answer your question at least in part while the comminity looks further into it.
"Virtual VLANs: Create an IP Subnet–Based VLAN
In an IP subnet–based VLAN, all the end workstations in an IP subnet are assigned to the same VLAN. In this VLAN, users can move their workstations without reconfiguring their network addresses. IP subnet VLANs are based on Layer 3 information from packet headers. The switch makes use of the network-layer address (for example, the subnet address for TCP/IP networks) in determining VLAN membership. If a packet is untagged or priority tagged, the switch associates the packet with any matching IP subnet classification. If no IP subnet classification can be made, the packet is subjected to the normal VLAN classification rules of the switch. This IP subnet capability does not imply a routing function or that the VLAN is routed. The IP subnet classification feature affects only the VLAN assignment of a packet. Appropriate 802.1Q VLAN configuration must exist in order for the packet to be switched."
You may find the manual here to read further:
Feel free to give us feedback.
Thanks
Evans-o
Please find the excerpt here:
For some reason, it didnt show up in my previouse post. Sorry about that.
Thanks
