HansRL's avatar
HansRL
Apprentice
Dec 29, 2021
issue with GS308T connected with readynas 212 via LACP
I have issues with connecting my readynas 212 to switch GS308T via LACP.
At the moment I connect the readynas all other connection freezes and/or loses their connection to the internet.
I defined in my
READYNAS RN212:
BOND0 with teaming-mode: IEEE 802.3ad LACP with Hash Type: Layer 2+3
GS308T:
LAG-configuration: ReadyNAS ReadyNAS l1 Enabled 2 Src/Dest IP and TCP/UDP Port Fields Enable Enable LACP
LAG-membership: LAG-id l1 ; LAG-name: ReadyNAS ; ports 4 & 5 selected
What am I doing wrong, any help is appreciated
rgds Hans
see also attached PDF
  • HansRL's avatar
    HansRL
    Dec 31, 2021
    @ schumaku Superuser Guru,
    thanks for your support, yesterday I started all over, disconnecting all cables etc... , during that process i noticed some cables were mixed up. After reconnecting and reconfigure the GS308T everything is working as it should.
    So my issue is solved.
    thx again.
  • schumaku's avatar
    schumaku
    Either we face a config issue, a problem with the LAG, wrong cabling - suspect some loop appears, or a port is shutdown.
    Check it the GS308T does run on the current firmware - update to the latest one from https://www.netgear.com/support/product/GS308T.aspx#download
    Double and tripple check the cabling and compare with the LAG ports configured.
    Start with connecting one of the two LAG links. Access the switch, and check the LAG status again. At least one port should be a LG member.
    Enable ssh root access in case it's not done already. Login using the root username and the (admin) password. Use (for example - assuming you are on a WIndows system) putty.
    Check these and post:
    root@RN212~# ifconfig -a
    LeafNets Link encap:Ethernet ...
    root@RN212:~# cat /proc/net/bonding/bond0
    Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
    Bonding Mode: IEEE 802.3ad Dynamic link aggregation
    Transmit Hash Policy: layer2+3 (2)
    MII Status: up
    • HansRL's avatar
      HansRL
      Apprentice
      The firmware of my GS308T is up-to-date
      Model NameBoot VersionSoftware Version
      GS308T1.0.0.11.0.4.4
      in the commands you proposed I see nothing strange, the commands are given at the moment the NAS is connected to a router (and not to the siwtch)
      IFCONFIG -a gives:
      root@Geldrop:~# ifconfig -a
      bond0 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
      inet addr:192.168.1.130 Bcast:192.168.1.255 Mask:255.255.255.0
      UP BROADCAST RUNNING MASTER MULTICAST DYNAMIC MTU:1472 Metric:1
      RX packets:11488654 errors:22 dropped:1337008 overruns:0 frame:27
      TX packets:7720651 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:5006522075 (4.6 GiB) TX bytes:6258859308 (5.8 GiB)
      eth0 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
      UP BROADCAST RUNNING SLAVE MULTICAST MTU:1472 Metric:1
      RX packets:9598419 errors:3 dropped:1828 overruns:0 frame:3
      TX packets:7289494 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:511986373 (488.2 MiB) TX bytes:1864575003 (1.7 GiB)
      eth1 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
      RX packets:524927 errors:15 dropped:823313 overruns:0 frame:19
      TX packets:2770 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:34733465 (33.1 MiB) TX bytes:304700 (297.5 KiB)
      cat /proc/net/bonding/bond0 gives:
      root@Geldrop:~# cat /proc/net/bonding/bond0
      MII Status: up
      MII Polling Interval (ms): 100
      Up Delay (ms): 0
      Down Delay (ms): 0
      802.3ad info
      LACP rate: slow
      Min links: 1
      Aggregator selection policy (ad_select): stable
      System priority: 65535
      System MAC address: b0:b9:8a:5d:ce:f2
      Active Aggregator Info:
      Aggregator ID: 3
      Number of ports: 1
      Actor Key: 9
      Partner Key: 1
      Partner Mac Address: 00:00:00:00:00:00
      Slave Interface: eth0
      MII Status: up
      Speed: 1000 Mbps
      Duplex: full
      Link Failure Count: 0
      Permanent HW addr: b0:b9:8a:5d:ce:f2
      Slave queue ID: 0
      Aggregator ID: 3
      Actor Churn State: none
      Partner Churn State: churned
      Actor Churned Count: 0
      Partner Churned Count: 1
      details actor lacp pdu:
      system priority: 65535
      system mac address: b0:b9:8a:5d:ce:f2
      port key: 9
      port priority: 255
      port number: 1
      port state: 77
      details partner lacp pdu:
      system mac address: 00:00:00:00:00:00
      oper key: 1
      port priority: 255
      port number: 1
      port state: 1
      Slave Interface: eth1
      MII Status: up
      Speed: 1000 Mbps
      Duplex: full
      Permanent HW addr: b0:b9:8a:5d:ce:f3
      Slave queue ID: 0
      Aggregator ID: 4
      Actor Churn State: churned
      Actor Churned Count: 1
      port key: 9
      port priority: 255
      port number: 2
      port state: 69
      oper key: 1
      port priority: 255
      port number: 1
      port state: 1
      • schumaku's avatar
        schumaku
        HansRL wrote:
         in the commands you proposed I see nothing strange, the commands are given at the moment the NAS is connected to a router (and not to the switch)
        Lot of things odd or strange. Trouble is we don't know anything about the router links and config, even less when problems arised.
        As requested, I suggest to test the LAG with the switch, start with one active link only. Reboot the NAS before so the strange errors on the LAG and the interfaces are reset.
        Marking some oddities hitting my eyes ... but again, with just two links connected to the router (and I guess no LACP config there):
        MII Status: up
        Up Delay (ms): 0
        Down Delay (ms): 0
        802.3ad info
        LACP rate: slow
        Min links: 1
        Aggregator ID: 3
        Number of ports: 1
        Actor Key: 9
        Partner Key: 1
        MII Status: up
        Speed: 1000 Mbps
        Duplex: full
        Slave queue ID: 0
        Aggregator ID: 3
        port key: 9
        port priority: 255
        port number: 1
        port state: 77
        oper key: 1
        port priority: 255
        port number: 1
        port state: 1
        MII Status: up
        Speed: 1000 Mbps
        Duplex: full
        Slave queue ID: 0
        Aggregator ID: 4
        port key: 9
        port priority: 255
        port number: 2
        port state: 69
        oper key: 1
        port priority: 255
        port number: 1
        port state: 1
ProSupport for Business
