BarriedaleNick
Jan 30, 2018Follower
Issue with Ports 41 through 48
We have an odd issue in that everythign works fine but if we plug something into port 41-48 that isn't a PC we get no traffic.
For example our network tester got nothing and our access control systems wasnt recognised - no traffic, no lights. PC - fine!
Are these ports locked in anyway or configured differently to the other ports?
We have a very basic setup - no VLANs etc just a flat 3 switch unit.
We have M4300-52G-PoE+ which I cant see int he drop downlist of model numbers
Cheers...
- JohnC_VNETGEAR Employee Retired
Hi BarriedaleNick,
Welcome to our community!
I suggest you to reset the switch to factory default just to check if the ports are still working properly. If the ports is still not working, please open a chat / case online on NETGEAR support and please let them know the status of your switch. Also be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
