arian_gh1
Apr 23, 2017Aspirant
It takes too long to get IP from the DHCP server,M5300-28G-POE+ ProSafe 24-port
Hi, I have two stacked M5300-28G-POE+ switch which are connected to the core switch and the core switch is connected to the default gateway. We have a DHCP server. The problem is that when we hav...
Retired_Member
Apr 23, 2017Hi arian_gh1,
Welcome to the community! ![]()
Let me try to understand your network info, but I still need more detailed inforation to debugging this problem:
1. two M5300 stacking with port 51&52?
2. One uplink port 2/0/49, connect to XSM7224S, and XSM7224S connect to DHCP Server?
3. Three 'Thrunk port' 1/0/49, 1/0/50, 2/0/50, connect to which Device?
4. Client get IP address on VLAN 16, right?
5. What is the current firmware version of the of M5300?
EricZ
NETGEAR employee
- arian_gh1Apr 24, 2017Aspirant
Hi EricZ,
Thanks for your comment.
1. two M5300 stacking via stack modules with stacking cables.
2.Yes
3.Trunk port 1/0/49 is connected to a third switch (M5300-28G-POE). port 1/0/50 is reserved for future use and is not connected to any device. port 2/0/50 is also connected to the third switch (M5300-28G-POE) via SFP.
4. Yes, exactly.
5. Stacked switches (52) ports has firmware "10.0.0.44" and the thirs switch which is under the stack has "10.0.0.53".
BR,
Arian
- Retired_MemberApr 24, 2017
Hi arian_gh1,
I suggest you upgrade M5300 firmware to latest verion and try again. As the current firmware is too old, and latest version is v11.0.0.28.
Below it the download link and release note:
https://kb.netgear.com/000036661/M5300-Firmware-Version-11-0-0-28
Note: as your switch version v10.0.0.44, it not allow to upgrade to v11.0 directly. If want to upgrade to v11.0, you should upgrade to v10.0.0.53 at first, then upgrade to v11.0.
Hope it can helps!
Many thanks for your comment.
I have another question regarding the management interface. In some switches we have the command:
network parms.....
which set the manegement interface.
But in some other devices, this command is not valid and we should create a virtual VLAN interface, enable routing and give it ip address to set the management interface.
Can you please prove my comment?
Many thank sin advanced,
BR,
Arian
