dave6592
Apr 09, 2017Aspirant
Java for GSM7212 and GSM7312
Hi
Trying to get my GSM7212 and GSM7312 device view to work.
I Have Java 1.7.0_79 installed and the switch addresses in the exception list.
OS is Windows 8.1
All I get is "You need JAVA Plugin. Get it from hear"
Can anyone tell me the correct way to get the "Device View" to work?
Thank-you
- DaneANETGEAR Employee Retired
Hi dave6592,
Kindly answer the questions below:
a. Have you tried using other browsers like Chrome of Firefox?
b. Have you tried using other PCs or laptops to isolate the problem? Also, try using other PCs or laptops with older Windows OS such as Windows 7.
c. Have you tried using lower versions of the browsers such as Internet Explorer 9?
d. Have you tried using Java 7 on Internet Explorer?
Kindly try the steps below:
On Windows, fix the java security settings to allow local trust to specific applets:
1. Go to Control Panel (It would be best to switch to Category View) then locate Java.
2. Open Java then edit the following security section.
3. Make sure Java is enabled in browser and if ever its not, add an exception for the switch IP address.
4. Make sure under Advanced, your browser is enabled for Java.
DaneA
NETGEAR Community Team
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- kgardnerAspirant
I've run into this problem too (I have two Netgear GS752TPS(B) switches), and would really like to solve it. I've given up on Firefox and Chrome, according to your notes, and am focused on IE since you seem to indicate that it would work better (even though I'd never use it otherwise! Isn't it EOL also?).
So just limiting the discussion to IE, my browser is enabled for Java, I've added the exception for the IP address of my switch (I added it as "https://10.0.1.67", accessing it only from within the same LAN, so another 10.0.1.x address; does that look right?). I am getting the message, "Error - click for details" and then "Application blocked. Click for details." Java is enabled, and I have version 8.0.1310.11 installed. Do I need to change security levels or something also?
- dave6592AspirantHi
It just doesn't work on windows ten and java whatever
That what I want and triedSame problem here:
https://community.netgear.com/t5/Managed-Switches/EOL-for-Java-new-FW-for-GS724Tv4/m-p/1117228
IE Tab is for Windows only!
I do not use Windows!
And how long will it work with Windows? As long as the IE rendering engine is in Win.
Don't know if Edge uses still IE rendering.
And may be it is not for free:
Netgear should think about a solution for vanishing Java.
Rgds
AW
