rfcat_vk
Jan 17, 2016Aspirant
JGS516PE not powerful enough for a 13w AP
I bought the JGS516PE in the hope of using it to power my AP which according to specifications uses 13 watts. The AP using the JGS516PE provides sufficient power to the AP so that the 2.4ghz band wor...
DaneA
Jan 18, 2016NETGEAR Employee Retired
Hello rfcat_vk,
Kindly answer the questions below:
a. What is the brand name and model name of the AP connected to the JGS516PE?
b. What is the current firmware version of the JGS516PE?
c. Did you try to perform a factory reset on the JGS516PE then reconfigure it from scratch and check if same problem occurs?
I look forward to your response.
DaneA
NETGEAR Community Team
- rfcat_vkJan 18, 2016Aspirant
I have answered these question in two different postings, but none of my answers appear here?
Ian M
- rfcat_vkJan 19, 2016Aspirant
I will reply again to this request.
The AP is a Sophos AP55c.
The current firmware is 2.0.1.26 which from memory is the latest on the Netgear site for this version of the JGS516PE.
I have not tried the complete reset to factory defaults and start a new configuration. I will do that shortly when my wife finishes her current internet session.
Ian M
