ossalanr
Jan 22, 2016Tutor
LLDP "Operational MAU type" (802.3 TLV) is zero for GS724Tv3
Versions Model Name Boot Version Software Version B5.1.1.1 5.4.2.19 I've enabled the optional LLDP TLVs on all my ports. When I receive the 802....
ossalanr
Mar 07, 2016Tutor
Hi AlexPe: 30 is what they should have supplied to me. By protocol design, all TLV data in LLDP comes from the switch. They supplied zero to me (oops!) This was verified through wireshark - on a couple of different systems, on a couple of different versions of firmware and also on the 8 port version (the GS108tv2).
The engineering team has all this information including a pointer to this thread, and has confirmed the issue to me just today and is working on a fix (hurray!). The fix won't be complicated - much of the data is just constants, or returning one of 3 or 4 different constants. I just continued to put it up here so the rest of the community could understand the issue, and be aware that it's broken as of right now.
The case number is 26364235.
ossalanr
Mar 15, 2016Tutor
AlexPe: I assume that this was what you needed? Let me know if anything further is needed.
- AlexPeMar 22, 2016NETGEAR Expert
Hi Ossalanr,
Yes that is all I need I can keep up with the engineering teams in house and see what is going to be done about this error. thank you.
Alex
