nag4591
Oct 31, 2024Aspirant
Looking for a Comprehensive GS724T (v6) Web Interface Reference Manual (pdf maybe)
Hi, I just bought a GS724Tv6 from Newegg. I can log in to the internal web management interface. But, I am now faced with hundreds of settings. I could stumble through them (using experience and ...
- Nov 01, 2024
Start from https://www.netgear.com/support/ ...
For the https://www.netgear.com/support/product/gs724tv6/ there is everything available - admit it's strange there is no Software Administration Manual for the GS724Tv6 yet, why ever.
Hope a moderator or a product manager does pick this problem up....
nag4591
I would have deleted the original post, but there is no option for deleting a post (even your own). In any case, I found my answer. The descriptions of all the web interface options are built into the interface - they are made visible as popups when clicking on the context-specific tiny circled question marks. After looking at a few of these pop-ups, I think there is sufficient detail such that I don't need an external reference manual.
My only suggestion is that the web site would point this out somewhere in the Netgear support pages. Maybe as one of the "Pick a Topic" choices.
Consider the original post solved.
Thank you.
- schumakuNov 01, 2024Guru - Experienced User
