Karlossimo's avatar
May 06, 2020
Lost access to Managed Switch via browser, prosafe utility & serial console port
I bought a used Managed Netgear switch Sept 2019 and have been using it with no issues. Recently I tried to login as I want to look at creating some VLAN's but noticed that there was no url to manage...
  • DaneA's avatar
    DaneA
    May 12, 2020
    Karlossimo,
    I reviewed again our conversation.
    I have tried connectiong through the serial port again. The switch is set to DB9 I have the serial cable plugged into the rear of the device. I have checked in the device manager and can see the USB-SERIAL CH340 (COM5) device is working with no errors.
    Since you tried using a DB9 console cable, this time, let's use the USB console cable that came with your M4100 switch package.  Be sure that the switch at the rear part of the M4100 switch is set to USB console.  For you to be able to use the mini USB port, you must install the USB driver on the computer. To download the Windows USB driver, click here.  As reference, kindly read pages 22-23 of the M4100 Hardware Installation Guide here.
    Also, try using another PC/laptop to further isolate the problem.
    DaneA
    NETGEAR Community Team
ProSupport for Business
