Karlossimo
May 06, 2020Guide
Lost access to Managed Switch via browser, prosafe utility & serial console port
I bought a used Managed Netgear switch Sept 2019 and have been using it with no issues. Recently I tried to login as I want to look at creating some VLAN's but noticed that there was no url to manage...
- May 12, 2020
I reviewed again our conversation.
I have tried connectiong through the serial port again. The switch is set to DB9 I have the serial cable plugged into the rear of the device. I have checked in the device manager and can see the USB-SERIAL CH340 (COM5) device is working with no errors.
Since you tried using a DB9 console cable, this time, let's use the USB console cable that came with your M4100 switch package. Be sure that the switch at the rear part of the M4100 switch is set to USB console. For you to be able to use the mini USB port, you must install the USB driver on the computer. To download the Windows USB driver, click here. As reference, kindly read pages 22-23 of the M4100 Hardware Installation Guide here.
Also, try using another PC/laptop to further isolate the problem.
DaneA
NETGEAR Community Team
DaneA
May 11, 2020NETGEAR Employee Retired
If ever the M4100 switch is still connected to your existing network, it is possible that it has obtained an IP address from your DHCP server which could be your main router. Kindly login to the web-GUI of your main router and check the attached devices. From there, you might be able to determine what is the IP address of your M4100 switch.
What is the behavior and status of the LED lights of the M4100 switch?
DaneA
Karlossimo
May 11, 2020Guide
Unfortunately it is not that easy. I have used Advanced IP Scanner to look for the switch with no luck. I also have a Unifi Security Gateway which lists all the devices connected and it doesn't show up there either.
The LED lights for each port behaves as expected with flashing green lights showing the gigabit traffic. I do have a couple of 100Mbit devices connected which is flashing orange/yellow. The Power light is lit and also the fan light.
Basically the switch is behaving well as a unmanaged POE switch. Unfortunately I need the managed functionallity
