Kwang
Apr 24, 2019Aspirant
M4100-26G Port occurred repeat UP/Down
Hi
Machin Model : M4100-26G
Software Version : 10.0.2.13
Bootcode Version : B1.0.1.1
occurred repeat This below message, why occurred this issue?
<13> Apr 24 13:51:25 XXX.XXX.XXX.XXX-1 TRAPMGR[49903252]: traputil.c(658) 1360 %% Link Down: 0/24
<13> Apr 24 13:51:24 XXX.XXX.XXX.XXX-1 TRAPMGR[49903252]: traputil.c(658) 1359 %% Link Up: 0/24
<13> Apr 24 13:51:22 XXX.XXX.XXX.XXX-1 TRAPMGR[49903252]: traputil.c(658) 1358 %% Link Down: 0/24
<13> Apr 24 13:51:20 XXX.XXX.XXX.XXX-1 TRAPMGR[49903252]: traputil.c(658) 1357 %% Link Up: 0/24
<13> Apr 24 13:51:16 XXX.XXX.XXX.XXX-1 TRAPMGR[49903252]: traputil.c(658) 1356 %% Link Down: 0/24
Please check it
Thanks
Hi Kwang,
Welcome to our community! :)
It seems that the device connected to port 24 is going up and down. May I know the device connected to this port? May you be able to attach or send the logs via pm so that we can check if there is anything out of the ordinary that happens to port 24 before this. If nothing happened in the logs, then you can try swapping out the cable.
JohnCarloV
NETGEAR Community Team
- JohnC_VNETGEAR Employee Retired
Hi Kwang,
JohnCarloV
- KwangAspirant
Hi
Thanks for your reply
We resolved this issue, after swapped cable
