adriaanmeeling
Jul 30, 2017Follower
M4100-26G Routing between Vlans and External Network
I have a M4100-26G switch which is a Layer 2+ switch. I have in internetprovider that gave me fixed ip addresses, which look like 82.151.55.150, subnetmask 255.255.255.248, and their gateway is lik...
- Retired_MemberJul 31, 2017
Hi adriaanmeeling,
Welcome to the community!
Client can't access Internet due to Switch doesn't support NAT function.
In your scenario, I suggest you deploy one Router or FW to connect to Internet, and all clients get IP address from the Router or FW. As Router or FW support NAT function.
Switch only working as L2&L3 switching role, cannot take the place of Router or FW role.
Hope it helps!
EricZ
NETGEAR employee
Retired_Member
Jul 31, 2017Hi adriaanmeeling,
Hope it helps!
EricZ
NETGEAR employee
- Retired_MemberAug 03, 2017
With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
