nsskyetech
Feb 27, 2017Aspirant
M4100-50G-POE+ Mirroring
Hello All; We have a M4100-50G-POE+. If I setup port mirroring, source 0/8 to destination 0/48, then I cannot remote control the PC (which has wireshark) on this port anymore. Mirroring turns ...
DanielZhang
Feb 27, 2017NETGEAR Expert
Hi Nsskyetech,
Welcome to NETGEAR community!
The port set to "probe" status will only work with mirror traffic.
You need to connect another port to control the Switch.
You can use following commands to undo mirroring:
no monitor // it will disable port mirroring function.
no monitor session 1 destination interface // it will undo probe port of monitor session.
May the solution help you.:smileyhappy:
- nsskyetechMar 01, 2017Aspirant
Thank you for the CLE commands to diable the probe.
I was able to set the port from probe to normal via the web interface by setting the destination interface to 'none' and apply.
Hope this helps someone else.
Have a god day.
- DanielZhangMar 01, 2017NETGEAR Expert
Thanks for the update. I'm glad to know that your mirror configuration deploy successful .:smileyhappy:
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
