dvz
Jul 03, 2018Aspirant
M4100: Can't access web interface since upgrading firmware
Hi all,
after upgrading firmware to 10.0.2.26 I can't access the web interface for configuring the switch.
console access works well. I ran the ezconfig to set up basic network stuff (including the device's IP) but no success.
Please, advice
1 Reply
- Retired_Member
Hi dvz,
Welcome to the community!
For M4100 switch, we used Management VLAN instead of Network. By default, the VLAN 1 is Management VLAN.So I suggest you set Management VLAN IP and default-gateway via Console port.
The cli command as below:
configure
ip default-gateway 192.168.1.1
interface vlan 1
routing
ip address 192.168.1.2 255.255.255.0
exitThen after configure success, you can show config to check if it is success:
show ip interface brief
show network
Hope it helps!
EricZ
NETGEAR employee
