KBC-UK
Jan 29, 2019Aspirant
M4100-D12G Sflow - empty packets collected by nfdump
Hi All,
I setup Sflow on a M4100-D12G (Vlan 1, 1 interface) sending traffic to remote host on the same network on TCP port 9995.
I can see packets coming (TCPDUMP) but I when I open packets w...
JohnC_V
Jan 31, 2019NETGEAR Employee Retired
Hi KBC-UK,
Welcome to our community! :)
It seems that you were trying to collate packets from your switch. May I know on how did you setup your port mirroring? I also suggest to upgrade the firmware to its latest version.
You can download the latest firmware here.
KBC-UK
Feb 13, 2019Aspirant
Hi All, I apologise for late response/update.
I followed documentation on https://kb.netgear.com/21920/How-do-I-configure-statistical-packet-based-sampling-with-sFlow-using-the-web-interface-on-my-managed-switch
I will copy and paste switch configuration within 4 hours on another post.
Best regards,
Jose
- KBC-UKFeb 13, 2019Aspirant
Hi All,
I attached sflow configuration. Oddly I can't see anything on the CLI/text configuration.
Hope this helps to pin point cause of the problem.
Best regards,
Jose
- KBC-UKFeb 21, 2019Aspirant
Hi All,
Please, could someone help me with this problem?
Thank you.
Best regards,
Jose
