mwgmwg
Jun 07, 2018Aspirant
M4100 DHCP over VLAN eating packets
I have the following setup:
pfSense Firewall -> Cisco Switch (servers) -> Cisco Switch (users) -> M4100-D10e -> Cable Modem
The pfSense firewall does the routing and NAT and is VLAN aware...
JohnC_V
Jun 11, 2018NETGEAR Employee Retired
Hi mwgmwg,
Welcome to our community! :)
As per checking, your pfSense firewall is at the bottom of your network which should be next to your cable modem. Is this how you want your network to be setup? Also, Have you tried setting up the M4100 in static?
- mwgmwgJun 12, 2018Aspirant
The pfSense firewall cannot be physically located where the cable modem comes into the building. They are about 800 feet apart and connected via fiber.
I have not tried setting it up in 'static', I'm not sure what that means exactly. But I'm sure it would work if I can make the switch a dumb layer-2 switch with vlan support.
- JohnC_VJun 12, 2018NETGEAR Employee Retired
Then you can just create a port-based VLAN in order for it to work. You can set all the specific members with U or Untag then set the PVID to its corresponding VLAN ID.
- mwgmwgJun 20, 2018Aspirant
That's what I have already. I know how to use the VLAN tagging on the switch, and it's working fine. It's doing something with the IGMP DHCP Messages being sent through the VLAN trunk, such that they're not re-broadcast to the port where the Internet bridge is on. It seems like's its intercepting the messages, and re-transmitting them locally, but never sends them back. I want it to just pass the IGMP broadcast messages like normal.
Trouble is, there are SO many options on this switch for how to handle IGMP, and I'm not sure which ones are enabled by default, and where to turn those off.
- Jun 23, 2018Retired_Member
