nhickey
Oct 26, 2016Aspirant
M4100 managed switches in series - dropping connection briefly
Hi all, Firstly, I'm totally new to this forum and have searched for my issue without success.. so apologies if this has been discussed before. The problem... I have an issue with a user usi...
nhickey
Nov 03, 2016Aspirant
Hi John / Erik,
Thanks for your replys.. they are much appreciated, and also excuse the delay getting back to you!
I have checked the port statistics as suggested. There are four ports in use, but they are all showing '0' for total transmit errors and total transmit packets discarded. When I try to ping the switch IP I get periodic breaks, so I figured that the uplink port (port 12 fibre port) would show an error, but it did not. Here is the statistics from the port, the stats were cleared in the last hour and a half, but the user has complained of drop out in that time period.. can you guys can see something I'm missing?:
| Interface | 0/12 | |
| MST ID | CST | |
| ifIndex | 12 | |
| Port Type | Normal | |
| Port Channel ID | Disable | |
| Port Role | Designated | |
| STP Mode | Enable | |
| STP State | Forwarding | |
| Admin Mode | Enable | |
| Flow Control Mode | Disable | |
| LACP Mode | Enable | |
| Physical Mode | Auto | |
| Physical Status | 1000 Mbps | |
| Link Status | Link Up | |
| Link Trap | Enable | |
| Packets RX and TX 64 Octets | 78023 | |
| Packets RX and TX 65-127 Octets | 114250 | |
| Packets RX and TX 128-255 Octets | 38808 | |
| Packets RX and TX 256-511 Octets | 27107 | |
| Packets RX and TX 512-1023 Octets | 9823 | |
| Packets RX and TX 1024-1518 Octets | 56225 | |
| Packets RX and TX 1519-2047 Octets | 0 | |
| Packets RX and TX 2048-4095 Octets | 0 | |
| Packets RX and TX 4096-9216 Octets | 0 | |
| Octets Received | 106342746 | |
| Packets Received 64 Octets | 65226 | |
| Packets Received 65-127 Octets | 65099 | |
| Packets Received 128-255 Octets | 34937 | |
| Packets Received 256-511 Octets | 22983 | |
| Packets Received 512-1023 Octets | 7947 | |
| Packets Received 1024-1518 Octets | 51359 | |
| Packets Received > 1518 Octets | 9 | |
| Total Packets Received Without Errors | 230492 | |
| Unicast Packets Received | 82407 | |
| Multicast Packets Received | 56898 | |
| Broadcast Packets Received | 91187 | |
| Receive Packets Discarded | 0 | |
| Total Packets Received with MAC Errors | 14255 | |
| Jabbers Received | 0 | |
| Fragments Received | 200 | |
| Undersize Received | 0 | |
| Alignment Errors | 0 | |
| Rx FCS Errors | 14055 | |
| Overruns | 0 | |
| Total Received Packets Not Forwarded | 9 | |
| 802.3x Pause Frames Received | 0 | |
| Unacceptable Frame Type | 0 | |
| Total Packets Transmitted (Octets) | 15104341 | |
| Packets Transmitted 64 Octets | 12797 | |
| Packets Transmitted 65-127 Octets | 49151 | |
| Packets Transmitted 128-255 Octets | 3871 | |
| Packets Transmitted 256-511 Octets | 4124 | |
| Packets Transmitted 512-1023 Octets | 1876 | |
| Packets Transmitted 1024-1518 Octets | 4866 | |
| Packets Transmitted > 1518 Octets | 0 | |
| Maximum Frame Size | 1518 | |
| Total Packets Transmitted Successfully | 76685 | |
| Unicast Packets Transmitted | 66702 | |
| Multicast Packets Transmitted | 6101 | |
| Broadcast Packets Transmitted | 3882 | |
| Transmit Packets Discarded | 0 | |
| Total Transmit Errors | 0 | |
| Total Transmit Packets Discarded | 0 | |
| Single Collision Frames | 0 | |
| Multiple Collision Frames | 0 | |
| Excessive Collision Frames | 0 | |
| STP BPDUs Received | 0 | |
| STP BPDUs Transmitted | 0 | |
| RSTP BPDUs Received | 6 | |
| RSTP BPDUs Transmitted | 2738 | |
| MSTP BPDUs Received | 0 | |
| MSTP BPDUs Transmitted | 0 | |
| 802.3x Pause Frames Transmitted | 0 | |
| GVRP PDUs Received | 0 | |
| GVRP PDUs Transmitted | 0 | |
| GVRP Failed Registrations | 0 | |
| GMRP PDUs Received | 0 | |
| GMRP PDUs Transmitted | 0 | |
| GMRP Failed Registrations | 0 | |
| EAPOL Frames Received | 0 | |
| EAPOL Frames Transmitted | 0 | |
| Time Since Counters Last Cleared | 0 day 1 hr 31 min 47 sec |
Thanks So so much,
Neil
- Retired_MemberNov 03, 2016
Hi nhickey,
Thanks for your updating immediately.
I found that there is some 'Rx FCS Errors' in the port statistics. Which type fiber module you are using? Could you change another pair of fiber module and try again?
Thanks,
Eric
NETGEAR Employee- nhickeyNov 04, 2016Aspirant
Hi Eric,
The SFP mudule we are using is a Netgear one.. here's a link:
Could there be a fault in the cable?? The trouble is, the cable connecting the two switches is under ground!
We have no spare SFP modules, and would need to get new ones. Would you recommend we do that?
Thanks,
Neil
Hi guys,
I have another possible theory.. could heat be a factor? I'll try to describe..
We have a (approx) 250 meter fibre connection between the server room and the first M4100 D12 switch. This switch is situated in a 'pavilion' type building beside some tennis courts. It's in a communications cabinet mounted onto the wall, but there is no cooling in this cabinet. The issue seems to have appeard as we have been coming into our summer (we're in Zimbabwe by the way!). Temperature wise, we were up to 41C the other day or 105 F!). The user seems to think it's getting worse too, which would go with the heat theory.
It's just after midday here, so I took a walk to check the units visually. I took out the SFP module going to the second D12 and found it to be very, very hot!. I'm starting to think that the heat could be the problem.. and that we may be reaching the temperature limit of these modules!
What do you reckon? am I clutching at straws, so to speak!
Thanks,
Neil
