SwanJovi
Jan 21, 2026Aspirant
M4250 A&H DX port profile
Netgear recently added a port profile for A&H GigaAce which is great. But I'm wondering how best to connect DX signals. They require the ports being limited to 100mbps which the GigaAce profile won't be. Could this be a request for a new port profile?
Dont think so. The profiles define different QoS aspects. And a Fast Ethernet device won't do anything different, regardless if connecting to a GbE, MultiGig. 10GbE port. port operating on higher data rates (2.5 G and up) are mandatory using link speed negotiation anyways.
- SwanJoviAspirant
The guidance from A&H stipulates that the connection has to be set by the switch to be 100mpbs as their testing showed that it wasn't reliable when left to auto negotiate. I assume these switches have the ability to do that, but that's obviously not a setting available in the AV interface.
What stops you from doing so?
Netgear Engage does provide simple options (sorry, rarely touch the local AV Web UI...).
That’s a fair concern. The GigaAce port profile is a great addition, but DX links are a different requirement since they need the port speed fixed at 100 Mbps. Because of that, the current profile doesn’t really suit DX connections.
A separate DX-specific port profile with a locked 100 Mbps setting would make things much cleaner and avoid per-port manual adjustments. For now, manually configuring those ports seems like the only reliable option.
