SwanJovi
Jan 21, 2026Aspirant
M4250 A&H DX port profile
Netgear recently added a port profile for A&H GigaAce which is great. But I'm wondering how best to connect DX signals. They require the ports being limited to 100mbps which the GigaAce profile won't...
SwanJovi
The guidance from A&H stipulates that the connection has to be set by the switch to be 100mpbs as their testing showed that it wasn't reliable when left to auto negotiate. I assume these switches have the ability to do that, but that's obviously not a setting available in the AV interface.
schumaku
Jan 25, 2026Guru - Experienced User
SwanJovi wrote:The guidance from A&H stipulates that the connection has to be set by the switch to be 100mpbs as their testing showed that it wasn't reliable when left to auto negotiate.
Interesting. Considering the A&H GigaAce is a Gigabit capable device (nomen est omen...). Have some references where this note is coming from exactly?
In the A&H Recommended Cables Guide they are mentioning for transporting audio between two nodes:
"dSnake, ME, ACE and DX links use 100BaseT Fast Ethernet, with 99.7% of bandwidth use. gigaACE uses 1000BaseT Gigabit Ethernet, with 93% bandwidth use. S-link ports auto negotiate protocol and link speed, switching to dSnake, ME, DX or gigACE mode depending on the connected device."
In my understanding, they are talking here of two adjacent nodes, directly connected. The negotiation applies to both the pure Ethernet PHY link as well as the effective transport over TCP or UDP. This is the "typical" definition from the earlier days of deploying AV networks. Can't get this myth away from the heads of some of my friends, that eg. Dante must be operated on a dedicated Fast Ethernet.
Where one dos deploy multiple DX devices on a switch (for carrying more concurrent audio channels), this "advice" does not make much sense to me, especially where more and different audio channels are sent to the GigaAce interface(s).
- SwanJoviFeb 01, 2026Aspirant
It's in their IO / networking guide that they say ports should be forced to 100mbps for DX. Page 21 of this:
https://www.allen-heath.com/content/uploads/2023/05/DX-GX-System-Guide-ISS_5.pdf
My use case - I have a pair of M4250 switches and I'm exploring what's possible with them. I already use them with VLANs for Dante, sACN, NDI and general data over a trunk but I'm curious as to whether I could squeeze DX or gigaACE over that trunk too (running at 2.5G of course).
- schumakuFeb 02, 2026Guru - Experienced User
Not a native English speaker. but as an decades long editor of product, project, SRS spec papers, and carefully reading IEEE, ISO, and IETF standards as well as product manual and some related white papers:
- Shall (or Must/Mandatory): Indicates a requirement that is binding, mandatory, and must be followed or implemented.
- Should (Recommendation): Indicates a recommendation or advice that is expected to be followed, but allows for flexibility or exceptions based on context (e.g., if it causes disproportionate cost).
- May (Permission): Indicates that something is permitted or optional.
The ports should be forced to 100Mbps (Fast Ethernet) for DX / ACE / dSNAKE, or Gigabit Ethernet for gigaACE - we had mixed experiences with auto-negotiating ports. The ports need full 100Mbps / 1000Mbps bandwidth. This means that, in order to have a gigaACE VLAN on a switch, the trunk between switches must be higher than Gigabit (10 Gigabit recommended).
===Reads to me like the many fairytales and myths still around in the AV industry. Ethernet ports don't randomly re-negotiate or fall-back from 1000Mbps to 100Mbps on a healty, undisrupted PHY connection.
This is a different "layer" than what is covered in the Netgear AV Network Profiles which do -not- cover -have to- care about the physical (access) or logical (VLAN trunk) port configuration. This is why you will likely never see a Netgear AV Profile forcing certain hardware setting, exclusively for a pure access port.
Said that: If you as the network admin want to follow that, you may be free to define the just these (two!) access ports myking up an extended, distributed VLAN connection, mimicking as a point-to-point connection on a physical cable.
-Kurt
PS. Not Netgear, just yet another active community member - supporting operators of many different multi-vendor networks.
