Gg72's avatar
Gg72
Follower
Oct 09, 2022
M4250 routing multicast ptp 224.0.1.129
Hi everyone,
Do you know if multicast intervlan routing of ptp (224.0.1.129) is possible?
I try with pim sm and multicast route static but it doesn’t work.
If you have the solution?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have an M4250, one of Netgear's managed switches. You wont find m,any knowledgeable users in a section given over to Nighthawk routers.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Switches - NETGEAR Communities
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
ProSupport for Business
