pieterjanheyse
Jan 26, 2018Aspirant
M4300 - M4100 and GVRP
I have a couple of M4300 switches acting as a new core stack, and using M4100 as distribution switches. Instead of manually configuring VLANs on all of the M4100 switches, I figured I'd use the GVRP feature. This seems to work, the VLANS on the M4300 get propagated to the M4100 (on port 11 & 12 of the M4100, what defines this?).
Then I want to assign a dynamic VLAN to a certain port on the M4100, for example, VLAN 1025. I select the access port 0/2, set access and native VLAN to 1025 and I get the error "Could not configure VLAN ID". I tried setting the PVID first, but that gives the error "Failed to set configured PVID with 1027". When using the VLAN membership page, and setting the port untagged, I get this error: "Failed to set VLAN membership for VLAN ( 1027 )".
What am I doing wrong here? I thought GVRP would make my life easier, but for now this isn't really working.
Hi pieterjanheyse,
Kindly try to set the VLAN Type from Dynamic to Static then try to modify the settings you prefer. Check if it helps.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi pieterjanheyse,
DaneA
- pieterjanheyseAspirant
I feel stupid not thinking about that. This works like a charm, thanks!
I'm glad to know that it works :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
