Demi_California
Jan 10, 2017Follower
M4300-12X12F 24-Port Managed Switch 10G link fails to come up with Intel SFP PN: FTLX8571D3BCVIT1
When Intel SFP PN: FTLX8571D3BCVIT is used inside M4300-12X12F 24-Port Managed Switch the 10G link fails to come up, an only way to get this link up is to go into switch configuration and make a manu...
Zebibyte
Mar 08, 2017Aspirant
Yes, the latest firmware has helped with the Intel SFPs, but I'm not sure if they would work with a direct attached cable or not. That introduces another SFP+ that Netgear would have to make work. I'm not sure if they have any DAC certified or approved yet.
sark
Mar 09, 2017Aspirant
Great thanks. So I will need to buy two LC compatible modules, one for the X520 and one for the 12x12. Any suggestions?
- ZebibyteMar 09, 2017Aspirant
Compatible modules on page 23/24 here http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf?cid=wmt_netgear_organic&cid=wmt_netgear_organic
- sarkMar 09, 2017Aspirant
I was hoping for a non-$300+ option.
- LaurentMaMar 10, 2017NETGEAR Expert
Hi sark,
I checked Intel® Ethernet Converged Network Adapter X520-DA2 specifications, and I don't think it should work with SFP+ optical modules (transceivers).
Instead, Passive Direct Attach cables seem to be required for each port.
On the switch side, we should now support any MSA standard-based DAC cable, including our AXC761/AXC763. But we know that servers are picky most of the time. I would advise you check with your DELL R510 server vendor, and requests the information for approved/certified DAC cables for your new server. This should be the best way to go.
- NickNakJul 19, 2017Aspirant
Hi,
I know this is an old pors, but just wanted to add some info to help anyone else.
I have the following hardware installed running VMware 6.x, and not experiancing any of the previously mentioned connection issues. Switches are on 12.0.2.12
2 x 4300-12X12F Stack
4 x Dell R810, with 1 x Intel82599EB 10 Gig TN, 1 x Qlogic NetXtreme II BCM57711 10 Gig cards fitted
1 x ReadyNAS 4312
2 x ReadyDATA 5200All of these are connected together with following SFP / DAC
Fiberstore SFP-10G-DAC (less than $20)
FiberStore SFP-10GSR-85 (less than $20)
Intel Corp FTLX8571D3BCV-IT 10GBase-SRThe FS kit was low enough cost to be worth a try, and I have to say all worked first time, and have seen no issues in production. The mentioned Intel kit was from some legacy kit, so no price known, but all works fine.
Nick
