JosLaan
Feb 28, 2017Aspirant
M4300-28G ip management port fails after restart in a stacked configuration.
Hello, we have a stacked configuration from 6 times a M4300-28G switch (firmware version 12.0.2.9), the stack up and running. The ip management port (IP4) is set to vlan 1 and via the web inter...
- Mar 16, 2017
Hi Jos,
We have received the TechSupport file just you sent to us.
This error may cause by serviceport enhancement in 12.0.2.x which add a new default IP address 192.168.0.239/24.
We also find a similar issue just like yours which will only appear on slave stack unit.
Maybe this issue have same root cause with yours.(default serviceport IP address)
So We will share the new firmware to you when the similar issue fix.
Please use a workaround method to avoid the error for now if possible:
Set the an another IP address on management VLAN.
Such as:
192.168.1.x/24
192.168.10.x/24
Thanks for your understanding and patience.
