jpass022
Feb 06, 2020Luminary
M4300-48X and ReadyNAS 4312X 10G NIC connection unstable
Greetings, I am experiencing this 10G NIC issue almost on a daily basis, seems to have gotten worse since the latest M4300 firmware update. I have logs from M4300 and ReadyNAS 4312X upon request......
DaneA
Feb 10, 2020NETGEAR Employee Retired
What cable are you using between the M4300-48X and ReadyNAS 4312X? Is it a CAT 6 or CAT6A or CAT7 ethernet cable?
I suggest the following below to isolate the problem:
a. Try to change the cable you are using between the M4300-48X and ReadyNAS 4312X.
b. Try using other ports of the M4300-48X.
c. Reboot the both M4300-48X and ReadyNAS 4312X.
DaneA
NETGEAR Community Team
jpass022
Mar 07, 2020Luminary
eth4 Link encap:Ethernet HWaddr e8:fc:af:e7:a6:ee
UP BROADCAST RUNNING SLAVE MULTICAST MTU:9100 Metric:1
RX packets:1406027554 errors:5269 dropped:689669 overruns:0 frame:5269
TX packets:174762969 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2070459717814 (1.8 TiB) TX bytes:93273137321 (86.8 GiB)
eth5 Link encap:Ethernet HWaddr e8:fc:af:e7:a6:ee
RX packets:480056614 errors:4366 dropped:382364 overruns:0 frame:4366
TX packets:673074932 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:674795922908 (628.4 GiB) TX bytes:721419014315 (671.8 GiB)
bond0 Link encap:Ethernet HWaddr e8:fc:af:e7:a6:ee
inet addr:192.168.1.50 Bcast:192.168.255.255 Mask:255.255.0.0
UP BROADCAST RUNNING MASTER MULTICAST MTU:9100 Metric:1
RX packets:1886084087 errors:9635 dropped:1072033 overruns:0 frame:9635
TX packets:847837874 errors:0 dropped:1691 overruns:0 carrier:0
RX bytes:2745255635339 (2.4 TiB) TX bytes:814692147028 (758.7 GiB)
