jpass022
Jun 16, 2019Luminary
M4300-48X Running Temperature high
I have a switch stack with the M4300-52G on top aand the 2 M4300-48X underneath. The M4300-52G operating temperature is 54C (stated max. in GUI is 90C). I can fell the air exhausting from the fans on the M4300-52G. Both M4300-48Xs have an operating temperature of 73C (stated max. in GUI is 75C). The case fans are running so slow that I can't fell air exhausting from the case and the fans on the PSUs are running. Is this normal for these switches? I would expect the M4300-48Xs to operate at a similar temperature as the M4300-52G. Plus the fans on the M4300-48Xs are operating way slower air flow wise than the M4300-52G. I hope someone has some ideas? Firmware on all 3 is - 12.0.7.15, B1.0.0.11 .
- jpass022Luminary
I am also amazed after going through the 1147 page CLI manual for the M4300-48X that this switch does not have user selectable cooling profiles the sames as my ReadyNASs do.
I don't think that's normal - open a support ticket via https://my.netgear.com/
jpass022 wrote:I am also amazed after going through the 1147 page CLI manual for the M4300-48X that this switch does not have user selectable cooling profiles the sames as my ReadyNASs do.
Network switches are - different from some (typically desktop) NAS - not operated in noise sensitive areas, and are configured to the best cooling possible. For some (smaller) M4300 models the fan algorithm was changed with a recent update towards non-rotating fans at lower to average temperatures, don't think this should apply to your versions.
- jpass022Luminary
I have opened a ticket, but no real help yet. I've done more testing in to the problem and the fans on the netgear labeled PSUs don't turn on when the swirch is powered up. But I happen to have a non-Netgear labeled compatible PSU that I installed to test how it reacts and the non-Netgear labeled PSU fan does operate when powered up. So I'm still dazed and confused that my new high end and expensive switches are having such basic issues with no quick solution as of yet. I also own Netgear's high end rack NASs and at least they have user selectable cooling profiles built in the firmware. I'm very disappointed so far, but hoping for better from Netgear...
