jdarow32
May 01, 2021Aspirant
M4300-48x failed switch replacement
https://kb.netgear.com/21904/How-do-I-replace-a-stack-member-on-my-managed-switch
This seems to indicate replacing a switch in the stack is non-disruptive.
We have a 2 switch stack. One died and was rma'd.
Followed the guide above. Switch booted as standalone. Manually configured the stackports, rebooted and it joined the stack.
Downgraded the firmware to master version by copying the image to the new member and rebooting the member.
Everything was fine for around 2 hours, then the master spontaneously rebooted.
Support hasn't been able to give me a good explanation as to why.
The docs don't mention a need to reboot the master to replace a failed member, but support says...
"It is normal when you add a switch to the stack you need to reboot the switches associated on the stack for the stack master to know the other switch added.
Particular to replacing a switch from the stack, the stack master don't know yet the new stack member and usually the reason why the stacking won't proceed without doing a reboot first on both switches once stacking ports are properly configured and Priority assigned on respective switches for the Stack election to happen again."
I don't get it. So there isn't a way to replace a failed switch without downtime?
Anyone have a method that has worked?
- DaneANETGEAR Employee Retired
Just found out from the NETGEAR Support Team that your support ticket got escalated to the higher tier of NETGEAR Support.
An e-mail was already sent to you regarding the feedback from the higher tier of NETGEAR Support. Please check.
DaneA
NETGEAR Community Team- msiLuminary
Hmm, interesting to read an update if you can share what actually whent wrong and what was the outcome / end result.
I have extended stacks online, but I have at first once been bitten quite hard which ended up in a big fat warning in our internal deployment guidelines for new switches: If no stack priority is defined and a failover happens, you may not exactly know who is going to take over. Since then our configurations always contain a defined stack priority for all members of a stack (switch priority command) and also who is pre-selected as standby master (using the standby command).
What happened is (likely) back then, is that we had a switch that was operating for at least 1y before a second member was bought and added to this stack. It had a much newer production date and thus higher MAC address. This new switch erroneously took over the role of the stack stack master. Since it had no configuration copied from the master (yet), all ports ended up unconfigured by and not management IP was set, so the stack was basically down. We had to power down the secondary unit, reboot the original stack member, set the its stack priority to 15 and then the new switch was able to join the stack without becoming the stack master.
If no priorities are defined, I guess that similar to the M5300 the M4300 will use their MAC address to decide the election of who becomes the new stack master, as explained here: https://kb.netgear.com/21879/What-is-a-stack-master-and-how-does-it-work-with-my-managed-switch
