knarfer
Oct 30, 2017Aspirant
M4300-52G-PoE+ loop error
Hello, i have a stack of 2 netgear m4300 switches. i also have a second stack of 2 m4300 switches. these stack is connected with a lag to the first stack. on the second stack is port 51 of each swi...
Retired_Member
Oct 31, 2017Hi knarfer
As all of switches in your network support STP protocol, so we suggest disable L2 Loop Protection function, the STP function will protect no loop in the network topology.
By the way, the L2 Loop Protection function is used for the scenario that access switch not support STP(such as: connect one hub).
If you enable STP and L2 Loop Protection, it maybe cause some unpredictable errors.
Hope it helps!
knarfer
Oct 31, 2017Aspirant
I disable L2 loop protection, still the errors appear in the log
- Retired_MemberNov 01, 2017
Hi knarfer
Could you please provide the tech-support file to us for further analysis?
How do I send tech-support?files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439- Retired_MemberNov 07, 2017
Hi knarfer
I notice that L2 Loop Protection is enabled on all ports.
interface 1/0/34
keepalive
keepalive action log
exitSo could you please remove 'keepalive' and 'keepalive action log' for all ports, and try again.
Thanks.
- knarferNov 09, 2017Aspirant
Hi Eric,
i change this to disabled:
still the same,
regards
Frank
