knarfer
Oct 30, 2017Aspirant
M4300-52G-PoE+ loop error
 Hello,  i have a stack of 2 netgear m4300 switches.  i also have a second stack of 2 m4300 switches. these stack is connected with a lag to the first stack. on the second stack is port 51 of each swi...
knarfer
Nov 09, 2017Aspirant
Hi Eric,
i change this to disabled:
still the same,
regards
Frank
knarfer
Nov 15, 2017Aspirant
Hi,
any update on this issue?
regards
Frank
- DaneANov 15, 2017NETGEAR Employee Retired
Since you mentioned that you have 2 stacks of M4300 switches connected to each other via LAG as well as other switches connected to the stack(s), just want to verify if you did the suggestion of Retired_Member to remove 'keepalive' and 'keepalive action log' for all ports on each stack and other switches?
Also, since you mentioned that you see "loop error" in all switches, I suggest that you try to disconnect the switch(es) connected to the 2 stacks of M4300 switches connected to each other via LAG and observe if the "loop error" will still appear. In this way, we'll know if the loop error originates on these 2 stacks of M4300 switches. Do this outside production hours.
DaneA
NETGEAR Community Team
