msi
Oct 28, 2018Luminary
M4300-52G-POE+ VLAN participation needed on stack-mode ports needed?
Hi
It looks like that when ports get switched over to stack-port mode you don't need to do much else but only switch to stack mode and reboot them. However I've recently converted 2 ports that prev...
- Nov 08, 2018
msi,
I just want to follow-up on this. Let us know if you have further inquiries.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Nov 04, 2018NETGEAR Employee Retired
Hi msi,
I inquired your post to the higher tier of NETGEAR Support. Here is the feedback of the higher tier of NETGEAR Support: "When the port is changed to stacking mode, it is not necessary to make any other changes to the port settings. Settings such as VLAN are not relevant when the switch port is in stacking mode."
DaneA
DaneA
Nov 08, 2018NETGEAR Employee Retired
msi,
DaneA
