montie_dj
Apr 21, 2020Aspirant
M4300 boot or firmware
Hello. Sorry about my english and mistakes in words. I have a swotch model m4300-8x8f. I buy used this dev. The is a problem with this switch. Switch not boot os. In terminal i have that msg: ...
Retired_Member
Apr 28, 2020Hi montie_dj
Welcome to Community!
Could you please login console port and input command 'reset' under m4300r2> mode? Then check if switch can bootup success or not.
If still not work, please input command 'setenv bootfile = image1', then do above operation again.
Hope it helps!
EricZ
montie_dj
Sep 30, 2020Aspirant
Retired_Member
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xf7b297f5, read 0x18ff4c2b
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 241:102864
UBIFS error (pid 0): ubifs_read_node: expected node type 1
UBIFS error (pid 0): do_readpage: cannot read page 12 of inode 96, error -117
Error reading file '/image2'
/image2 not found!
Bad FIT kernel image format!
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0x5014e6e3, read 0xe250c3bc
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 318:92912
UBIFS error (pid 0): do_readpage: cannot read page 18 of inode 95, error -117
Error reading file '/image1'
/image1 not found!
/image2 not found!
## Error: "tftp_boot" not defined
Hello.
THx for email.
Unfortunately your solution its not working.
After reset i have the same erro, after write setenv - the same
