floriletterman
Jul 15, 2021Aspirant
M4300 factory reset not working
Hi, i have a problem with my M4300-8X8F (XSM4316S). I can't remember any login user data so i tried to start to reset password for admin user. I used this how-to: https://kb.netgear.com/30326/M4300-...
- Jul 19, 2021
Hey everybody,
today i was able to reset the switch and change the password. While i took some screenshots it worked during my third try. Don't know why or why not in all the other attempts.
Thanks for your support, i'm now loged in and can configure the switch again.
With kind regards,
Florian
floriletterman
Jul 17, 2021Aspirant
Hi schumaku and JohnC_V,
thanks for your reply. That's right, the attached image is while trying to reset to factory defaults. Getting into boot menu isn't a problem, just all the described command are not working.
On monday i can post more pictures when i'm in front of the device.
Thanks for your help.
With kind regards
Florian
floriletterman
Jul 19, 2021Aspirant
Hey everybody,
With kind regards,
Florian
