knarfer's avatar
knarfer
M4300 firmware update 12.0.7.15 WAC720 unusable
Hi,
i update one of my 4300 switches. On that switch there are 2 wireless access points (WAC-720) connected.
The access points are connected to a controller WC7600.
after the update the 2 AP's are unusable. On the AP's the power led's are blinking red and devices cannot connect.
I have to update other m4300 switches where there also AP's connected and do not want there are all unusable.
regards
Frank
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    knarfer,
    Is the M4300 switch the DHCP server for the 2 WAC720?  If yes, kindly configure the DHCP server on the M4300 switch for the 2 WAC720 and check if the same problem will occur.
    Check page 93-97 of the M4300 user manual here on how to configure DHCP Server Settings.
    DaneA
    NETGEAR Community Team
    • knarfer's avatar
      knarfer
      Dane,
      the switch is not dhcp server. also the ap's have a fixed ip address.
      regards
      frank
      • DaneA's avatar
        DaneA
        knarfer,
        Are the 2 WAC720 still in the managed list of the WC7600?  If not, run the discovery wizard on the WC7600 to find and the access points back to the managed list.  Kindly read page 155 of the WC7600 user manual here about Discover & Manage Access Points.
        DaneA
ProSupport for Business
