oheymanns
Nov 26, 2018Aspirant
M4300 Inter-VLAN routing not over default gateway
Hello Community, I need your help, please. Maybe this topic has already been discussed here, but unfortunately I have found nothing. I have two questions about the switch. 1. We have created 3...
- Nov 28, 2018
OK thank you very much. I believe it won't work per your requirements with current static routing. I would revert back to pure Layer 2 installation of your VLAN 12 and your VLAN 21. These two VLANs should not be "routing VLANs" anymore and all their traffic should be sent to your firewall straight. A trunk with all VLANs should go to your firewall and your firewall should act as the gateway for VLAN 12 and VLAN 21. This way, your firewall rules will function normally. schumaku do you think the same?
The switches' management VLAN 254 can remain a routing VLAN, in order to let all services function normally in the switch. I hope this helps -
schumaku
Nov 26, 2018Guru - Experienced User
Aehm, wild guess this is because of these PCs are using the Sonic Wall IP as the default gateway. In the "fun" of a static IP routing environment, you have to make the relevant switch routing interface the default gateway instead.
oheymanns
Hello schumaku,
Thank you for your prompt reply.
No, the switch is the gateway for the PCs. Please see the attachment below.
- oheymannsNov 26, 2018Aspirant
The second picture is the packet capture of my sonicwall. You can see the ingress interface.
- schumakuNov 26, 2018Guru - Experienced User
Still correct - looks like the switch default gateway (configured along the management IP config) is on the VLAN 256. The fun of static routing. All traffic flowing out over one VLAN, over that one subnet with the (management, sigh...) IP network, nd that network is on VLAN 256.
You seem to expect that the switch does inter-VLAN routing while keeping the "outgoing" traffic dedicated on each VLAN which is connected to the security appliance, do you?
No, i know the definition of the defaut route and i know that the switch does everything right. I am not expecting that the switch send the traffic to dedicated vlan but i would make my job easier if it worked.
If it does not work, then please answer the second question. How can I prevent the PCs from accessing the web interface?
THX!
