oheymanns
Nov 26, 2018Aspirant
M4300 Inter-VLAN routing not over default gateway
Hello Community, I need your help, please. Maybe this topic has already been discussed here, but unfortunately I have found nothing. I have two questions about the switch. 1. We have created 3...
- Nov 28, 2018
OK thank you very much. I believe it won't work per your requirements with current static routing. I would revert back to pure Layer 2 installation of your VLAN 12 and your VLAN 21. These two VLANs should not be "routing VLANs" anymore and all their traffic should be sent to your firewall straight. A trunk with all VLANs should go to your firewall and your firewall should act as the gateway for VLAN 12 and VLAN 21. This way, your firewall rules will function normally. schumaku do you think the same?
The switches' management VLAN 254 can remain a routing VLAN, in order to let all services function normally in the switch. I hope this helps -
schumaku
Nov 28, 2018Guru - Experienced User
The routing problem is related to the fact that the L3 switch/routers do the full routing, anything beyond the Inter-VLAN routing does flow out on the [management!] VLAN holding the switch CPU port default gateway (except of what might be rerouted by static routes). I would love to hear if LaurentMa has some magic hands (read: more product insight) to proof I'm wrong.
LaurentMa
Nov 28, 2018NETGEAR Expert
We would need to see the routing table before making any guess (would a Layer 2 setup be more suitable to your application, or should we continue tuning the static routes).
Please post a screenshot of the Weg GUI learned routes at Routing\Routage Table\Advanced\Route Configuration - thanks in advance
- schumakuNov 28, 2018Guru - Experienced User
LaurentMa on a side note: Users are often confused because we tend to talk of "Inter-VLAN routing" in the documentation and the community. This does raise the impression that L3 routing can work "just" for the routing between the VLANs, while everything else can be covered the L2 way e.g. a VLAN traffic can be "routed" to a direct L2 connection.
- oheymannsNov 28, 2018Aspirant
learned routes
10.21.12.0 is an other VLAN 12 for other PCs on an other M4300 switch with the ip 10.21.254.241. Do you need any other information?
- LaurentMaNov 28, 2018NETGEAR Expert
I already thought so. Now I have also the proof. Thank you both for the clearing and the help!
