boe
Dec 14, 2025Luminary
M4300 only boots when TFTPD connected
Hello, I posted a previous post and got some great help but it looks like there is a part 2 and I jumped the gun on thinking I had it all figured out. I had to reset a switch to the beginning...
boe
OK - I don't know what I'm doing but I finally got it to normal.
I booted it off the tftp
Then from the console I went to enable
then I went to clear config
rebooted it and now the GUI shows the firmware and I was able to upload to image2 using the gui.
Thought I'd post in case anyone else happened to come across this same situation.
