fireflysvennd
Nov 30, 2020Follower
M4300 really hot
We have 3 M4300-24X, they all 3 are really hot to touch; One of them is not even used (its just connected) is this normal ? Unit ID 1 2 3 4 5 6 7 8 MAC 69oC 67oC 70oC ...
schumaku
Dec 03, 2020Guru - Experienced User
Just curious, what is the physical set-up and mount installation of these three switches?
Installed in a pizza-oven-like environment above some fat server blade systems in a non A/C'ed rack?
- svenndDec 03, 2020Aspirantroom is about 21°C below are storage servers but those don't become 70C we also have 2 smallish clusters run at 45C.
even idle do these run 65C
really thinking its the model. im in touch with support now :)- Retired_MemberDec 03, 2020
For M4300-24X sample, we have adjusted fan policy for XSM4324CS at the beginning of this year, need upgrade CPLD to v06. I will share the CPLD file and upgrade method to you by Private message. Please follow the steps to upgrade CPLD, then check if can resolve your problem or not.
Eric
