mobocracy
Aug 05, 2025Aspirant
M4350 - How do I disable auto vlan 1 on a port?
When I set a port in general mode: interface 1/0/10 description "A general mode config port" vlan pvid 10 vlan participation auto 1 vlan participation include 10 exit I get "vlan partici...
fahadadi
Sep 01, 2025Aspirant
You can not really stop VLAN 1 from showing up on these switches. It is always there as the default. The trick is to make sure VLAN 1 is not tagged or untagged on the port so traffic does not leak. I usually just leave it present but remove any untagged assignment. Did you try setting the port mode to trunk instead of general and then exclude VLAN 1?
