TimJL
Jan 05, 2016Tutor
M5300 Summer Time / Day Savings config bug.
Hi there, I'm configuring the day light savings rules on a new M5300 after updating it to V11.0.0.14 and have found what I think is a bug unless someone can advise me otherwise. I'm trying ...
DaneA
Jan 05, 2016NETGEAR Employee Retired
Hi TimJL,
Welcome to the community! :)
Have you tried to factory reset the M5300 switch after updating the firmware to the latest v11.0.0.14? If not yet , kindly perform a factory reset then reconfigure the M5300 switch from scratch. Afterwards, check if same problem occurs when you enter the same CLI command.
DaneA
NETGEAR Community Team
- TimJLJan 12, 2016Tutor
Hi Dane,
The switch has gone into production but I did this and it still errored on the CLI command.
Tim
- DaneAJan 12, 2016NETGEAR Employee Retired
Hi TimJL,
With regard to this, I encourage you to open an online case with NETGEAR Support and let them know about your concern.
DaneA
