jlusky
May 25, 2016Follower
Management IP after upgrade to 10.0.2.13
I just upgraded my M4100-50G-POE+ to firmware 10.0.2.13 (from 10.0.1.16). I was not using IP routing before, and my managment vlan is 1102 instead of the default vlan 1. After the upgrade, I am no ...
Retired_Member
May 28, 2016The network parms was to configure the CPU interface. NETGEAR removed it (cf release notes).
Now, the management interface is really a VLAN interface.
As the command network parms has been removed, you can't do a no network parms.
Two solutions:
1) use ezconfig to set your management IP, it will remove the network parms
2) extract the config, remove the network parms line, clear config, reinject it, add an IP to vlan interface 1102
Two solutions:
