vbecque
Apr 25, 2022Follower
MRouter port automatically enabled
Hi,
I have 7 switches connected in a simple mesh/loop architecture.
Multicast is enabled at switch and VLAN level.
No MRouter port are configured.
STP is enabled.
I have some bandwidth problems: If I monitor my ports, I see some upload ports with a huge bandwidth (one port per switch/stack and about 2-3 Gbps usage). They are 10 Gbps ports. When I look at the configuration, I see one MRouter port enabled. I cannot disable it. Web interface and console doesn't have any effect on it. I think that I need to find who is enabling it but I don't manage to find the source.
Any idea?
Kind regards,
Vincent
No RepliesBe the first to reply
