Neilio
Jan 09, 2018Aspirant
Multi-gigibit switch and 10GB switch?
Hello,
I see that there are some newer multi-Gigabit switches out that work with Smart Control Center, this is great but they are lacking the ability for full 10Gb across all the ports. Do we know if Netgear will be releasing any full 10GB switches like the Gs108tV2 and or GS110TP.? I do see the other Multigig switch available under the Plus switches (GS110EMX ) but this doesn't work with the Smart Control app and is only 2x 10Gb ports. Would really be Nice to see fully 10GB Small desktop version in the line up soon.
Thanks
Unlikely. The thermal requirements (heat dissipation) of eight or then 10 GbE/MultiGig ports are extremely high - this does not fit into these small flat desktop enclosures. Get a GS110EMX and you get an idea what i'm talking about there.
- JohnC_VNETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
Neilio wrote:I do see the other Multigig switch available under the Plus switches (GS110EMX ) but this doesn't work with the Smart Control app and is only 2x 10Gb ports.
Curiosity question: What is the killer feature of this Smart Control Center App?
JohnC_V wrote:
NETGEAR has a full 10GB switches which is the 10-Gigabit Smart Managed Pro Switch. This is also compatible to smart control center.
Nothing silent for the desktp and enclosure sizes the OP was asking for, isn't it?
